RSB0072 radar array not turning
Lupie
Hi! RSB0072 radar array not turning. After hitting transmit, the radar screen shows like the radar is on, but the array is not turning and is not showing any objects. We have an MU-155C display and an RPU-15 processing unit. It seems like the longer we let the radar warm up, the better the chance is of the array working. Thanks for any help you can provide.
It could be the motor, power supply (in between display and radar) or the cable. Are you getting any alarms associated with the problem? If you would like to see if someone can come out and look at it, please use our Dealer Locator: https://furunousa.com/en/company/find_a_dealer
There are no alarms going off at any time. The boat prior to our ownership had the generator rebuilt ( the power generating part ) and the previous owner said the problem started after that. I have found recently that if I start the warm up process for the radar prior to starting the generator the array will turn. If I start the generator first the array will never work. All of the batteries have been replaced in the house battery circuit which both the flybridge power and the generator share. Ocean Yacht, go figure. I am going to try to isolate the two systems and see if the problem persists.
