Rotokey delay
northcaptain
Is it possible to adjust the rotokey delay (when it disapear after a few second) because when the MFD12 is working a lot (autopilot, radar on, route display on the map and then the two radar windows), it is almost impossible at sea to get the correct item on the first time. Is there an option or a way to extend the period on request ?
No, there is no time adjustment on the Roto-key time out. You can customize the Roto-key to eliminate selections that you don't use. As long as there is movement, the Roto-key will reset the timeout. If you need more time to make your selection, you can just move the knob and move it back to reset the time.
