jennyleigh
Hi, I have a NN3D MFD12 set to master. It has a Garmin NMEA2K antenna on the backbone.
On the ethernet network is sounder module, radar, the master NN3D and a second MFD8
Only the MFD12 is set to master.
All works fine and master has position until I power up the MFD8.
When either powering up the MFD8 or putting MFD8 in installation mode after power up the master will lose position and neither unit will have a position for about 10 minutes. Then both will finally have a position.
The MFD8 is not connected to the NMEA2K backbone, it's only connection is by Ethernet to the network hub.
I'm trying to figure out why position is lost every time I power up MFD8?
Any help is appreciated.
