You would need to find what you need on the used market. The 24pin connector is molded onto the cable so you would need to find a replacement or splice it back on properly.
Ok I think I only have one last question for you guy’s, I have a 37’ cable that I want to use for my 1934c 12kw to connect from my VX2 to the PU-005 that I need to terminate the Molex connector and pins to could I shorten that cable to 30’ without an issue is there a magic number in ft that is acceptable? Or shorter?Regarding the little molex connectors here are some part numbers.
VH9 Housing - 000-505-893
VH4 Housing -000-505-887
VH Pins - 000-100-049
NH13 Housing - 000-505-610
NH Pins - 000-505-504
Is the PSU005 power LED ON? Does it stay lit after going to transmit? Have you setup the display antenna type and needed configuration using the installation manual? It should be setup as a 1954C.
