Radar
You would need to find what you need on the used market. The 24pin connector is molded onto the cable so you would need to find a replacement or splice it back on properly.
Is this the right cable connection from psu -005 to antenna? The other end is plugged into the psu-005 with round 24 pin connector.
The other cable has a round 24 pin connector to plug into the vx2 is missing the flat pin connectors.
I believe this is what I need the 3 connectors that plug into the psu under the cover.
Referring to the manual the radar cable going to the radar will have a molded plug. The short one from the display will have a molded plug and then three little molex connectors to go into the PSU005. To check to see if you have the correct cables, please refer to the detailed drawing on page S-1 of the installation manual. 1749046189244.png
Regarding the little molex connectors here are some part numbers.
VH9 Housing - 000-505-893
VH4 Housing -000-505-887
VH Pins - 000-100-049
NH13 Housing - 000-505-610
NH Pins - 000-505-504
Ok I think I only have one last question for you guy’s, I have a 37’ cable that I want to use for my 1934c 12kw to connect from my VX2 to the PU-005 that I need to terminate the Molex connector and pins to could I shorten that cable to 30’ without an issue is there a magic number in ft that is acceptable? Or shorter?
Between the Machine and PSU005 is limited to the stock 5 meters. Between the PSU005 and the gearbox is limited to a max of 30 meters.
At min you need 5 meters to the gearbox or the timing will be off.
