Radar compatibility
fireescape
Hello I recently acquired a RDP-150
My older array a RSB-0070, R100-3114
FCC # last 4: R059
I hooked this pair up, not on boat yet. Seems to work, i'm wondering about compatibility
That's cool if it works...
The RDP150 most likely came from the FR8062 radar. Where as the RSB0070-059 scanner came from the 1942MK2 radar. It appears that scanner wasn't the original scanner for the FR8062.
Hope this helps, :sail
- Maggy
While you might have them appear to be working in your test; they are not compatible and you can expect to run into some problems if using them together.
