Good morning Moonzy,
With the 275 and the wider beam, especially on the High Frequency, you can use gain offset to help the effects of attenuation.  The gain offset will help increase or decrease the front panel gain.  So say your HF Gain Offset is set to "0" and your Front Panel Gain is set to 5.  If you increase the HF Gain Offset, your front panel gain set at 5 is higher and much hotter.  5 is the new 7,8 etc.  with an increased gain offset.
