New user. Problem tzt2
The orange wire is the xid to identify the transducer. I disconnect orange wire? for transducer B265LH to dff1-UHD?
Correct, disconnect the orange wire. There have been some problems with that TID connection on the UHD and it is best to remove it and then setup your UHD transducer manually.
Sorry, the transducers were modified. Those were old photos. I send you new photos. are the transducers very close together? Which is the best option? put all transducers in a single shell in a homemade way
the transducer and decided to put where the old transducer was placed
Take your advice from the Furuno technicians— but whoever is doing this work is NOT following recommended practices! Those are very poor locations!
Igna_78":9roevqg7 said:
Where do you recommend putting the transducer? and put the three tramsductors in a single hand-made boat?
Kind of hard to be 100% with the pictures but are the transducers forward and aft of each other and slightly off to the side of each other?
If that is the case, I would recommend them being directly forward and aft of each other and if you're going to space them out like that, it needs to be spaced out wider because the forward one is cutting the water and making bubbles into the aft one when is it slightly off like that. So my recommendation would be to either put them directly inline with each other or put one of the transducer on the other side of the boat.
Ideally one would be on one side of the boat and the other on the opposite side of the boat. I agree with others that the current install is too close together and wouldn't have been where most installers would have chosen. Have you talked to Furuno Spain, which is your Furuno distributor? You are outside our sales and service area. You should be opening official support channels with your distributor.
everything has been put through furuno. Initially I was told that I had problems with the Cutter Gain and TVG settings. Thanks to you, I found out the interference due to missing the earth wire. If I put the transducers in line, I must modify the engine's water intake or put it to the starboard side. I am thinking of putting both transducers in a single hand-made transducer. What do you think where I think I should put the transducer? in the future I think I want to add the Di-FFAMP box with a 2 / 3kw transducer and I was planning to put on the starboard side so for now I only want to use one side
