Hello!!
I have a 8.40 Starfisher in which I have assembled a new equipment:
Furuno sounding line
12” TZTOUCH screen
DFF1-UHD module with airmar B265LH chirp transductor
DFF3D with airmar B54 transductor
HUB-001 (switchboard)
computer with Timezero
CMAP Cartography
I have a lot of problems with the sounding line. The DFF3D module doesn’t go ahead longer than 10 meters, the movement sensor has been configured recently to try to solve the problem.
The DFF1-UHD has a lot of problems to mark the depths, the high frequency doesn’t go ahead longer than 70-100 m. and the low frequency, although it draws in 1200 m., has problems to draw the depths and it doesn’t mark the numeric meters although it is in manual scale. It only mark fish until 100 meters.
Configuration: manual transmission to 20. Manual scale. No acufish. No dephts detection.
Cutter and gain configuration, according to depths and sea circumstances. Tvg 5until 200m. Tvg 3 between 500-800m.
I was guaranteed that DFF1-UHD marks depths until 1200 m. and fish until 800 m. and DDF3 marks depth until 300 m and 3D until 200 m. How is the capacity of the sounding line to mark the fish in meters?
I have a lot of problems to mark the depths and the sounding line quality to mark the depths works sporadically.
To 10m of depths and manual depth, the low prescience do 6 depths and high frequency only 2 depths . I am waiting for a checking on the transductor state with TDT 1000.
Another doubt, can I have problems with the pitching although I have connected the bottom heaving correction? Is it necessary use the pitching sensor in a 8 m boat when I am fishing in a tidal wave? Is it possible to correct the pitching with a PG-500 compass or is it necessary a SC-30 type satelital compass?
Thank you
12” TZTOUCH screen
CMAP Cartography
Thank you
