Alaskamariner
Can the SC33 be connected directly to a NEMA 2000 Back Bone, which appears to connect via a drop cable to port TB11 on the FAP-7002 processor unit. I have posted questions aabout the Auto Pilot hookup before, but had to change from FAP-711C to the FAP7001 because flush mount was not an option, and there are no brackets for the FAP711 even thought some documentation give part numbers; we were told that the Part does not exist. Since the plan is to use the SC33 instead of the PG700 to supply heading data. Do we just ignore TB6 or do we need something of a connection there.
Can the SC33 be set up from the TZTL12F or TZTL15F or is it by laptop only
If we have a teminator on each end of the backbone, do we just ignore the terminator on the Canbus port TB11.
Always open to hearing how it should be done.
Thanks,
Phil :questions
Thanks,
Phil :questions
