My NavPilot 511 was installed new in 2006. After recent rudder and post removal, repair and reinstallation, the NavPilot reads 1-2 degrees to starboard when the rudder position is "neutral" (0 degrees) while underway at cruise speed. I know the rudder position sensor rod is mis-adjusted but access to it is difficult. Is there a way to compensate by re-calibrating the NavPilot to read 0 degrees when the rudder is centered without having to struggle with and readjust the position sensor rod?
Thank you for the help.
