spindrifter
After a day of fishing with the NavPilot 511 autopilot working normally, it stopped working apparently due to a heading issue.
I first noticed a deviation alarm (autopilot not able to keep commanded course) and that the rudder angle indicator on the autopilot controller was stuck around 21 deg to starboard. (Normal range is 30-34 deg each side). The autopilot was apparently not able to turn to starboard sufficiently to keep course and the rudder angle indicator stayed around 21-24 deg to starboard.
Then there was a different alarm, something like “Heading (or rudder) sensor drift” but I can’t remember exactly or find it in the manual. I checked the rudder angle sensor arm that connects the sensor to the rudder and it was still in place (I replaced it about a month ago).
While driving manually to an anchorage, I ran through the test menu, but nothing worked. The autopilot read about 21 degrees to starboard when the rudder was centered while driving. This is when I noticed that the NavPilot’s heading readout was consistently about 20-25 deg to starboard of both the GPS and the chart plotter’s internal GPS. All are in degrees magnetic. (When the standalone GPS and my chart plotter read a course/heading of ~ 000 deg M, the autopilot read about 025 deg M.
This seems to be the issue but I can’t figure how to reset or recalibrate the autopilot.
After anchoring and shutting down the autopilot and restarting it this morning, the rudder angle sensor seems to be back in order (the port/starboard rudder angles are about 31 deg either side). I’m about to head to town and I’ll report what I experience otw back.
