Hi, I have a vx2 system on my boat and have recently replaced my old sounder module with a dff3. I am using a 2kw 200 hz tranny for shallow water which works great and recently installed a 2kw 50 hx tranny for deep water the problem is that the 50hz will not register bottom in 150 metres of water it seems that the signal is too weak, when you put your hand under the 200hz you can really feel the pulse but under the 50 the pulse seems very weak is there any way of testing a tranny to make sure it is working properly or do you think that it would be a settings problem,
Cheers,
Rosco.
Cheers,
Rosco.
