Hi - I have a Navnet vx2 with a GD-1920C GPSplotter and a 1824c radat. Last fall the plotter started turning off intermittently when the boat is rolling from side to side, generally when sailing downwind in a swell. It does not happen when the boat is beating. When I manually move the unit in imitation, it doesn’t turn off.After the motion calms It has started up again. We are in Croatia but did find a Furuno dealer to update the hardware last October and to test the electrical connections. We also changed the c map card this spring. But the plotter continues to turn off. And ominously yesterday when I tried to restart it blinked once and refused to start. I tried multiple times. Then this afternoon it started again. We have not been using radar, only the plotter. When plotter is working, the radar also works. I have taken off the connections and reconnected but that makes no difference. I am also clearing out some memory in case the plotter is overloaded
Help is appreciated
Help is appreciated
