dustinzstingray
Hi
Wondering if anyone has heard any problems with getting a axis ip cam to be seen on a tz3?
Im struggling here. I have a M2025-LE camera. I tried plugging the ethernet into the tz3 directly and have tried in a basic network hub. I have no problem getting into the configuration page and viewing the live camera feed on a laptop. I don't thing there is a problem with our camera.
I followed the instructions that are on the furuno website where it tells to re assign the ip address of the camera. Going through the axis IP utility like it says in the furuno instructions got me nowhere. It kept failing the reassigning ip address. I talked to axis and they told me the cameras with newer firmware can no longer be changed using the ip utility app, but need to be changed in the axis device manager. I'm not having any luck changing it to the 172.031.200.003 that is mentions in the furuno instructions. I thought i had it changed but the tz3 gives a problem decoding or connecting error.
I'm afraid there is something im missing because i'm certainly no network wizard.
Can anyone point me in the right direction? Thanks agian.
