Hi.
After 8 long years I have returned to my boat. I reconnected my MFD8, and FI50 displays and what did I find.
I found that the GP330B and Radar aren't being found by the MFD8.
I checked the wiring and found that ALL the plug connections have disintegrated. I have done field replacement of plugs and also run new backbone wiring where required.
Still not able to find Radar and GPS. My reckoning is that the backbone is OK.
The FI50 panel is working from the FI5002 junction. I believe this powers the backbone. So accidently found that if I disconnect the drops to the sensors the MFD8 beeps. I figure it knows there is a disconnection. So is wiring OK ?? - I think so
My system is FI5002 to FI50 Displays, Nav711, MFD8 and a drop to the backbone. Backbone has DST800 and PG70 compass being found by MFD8 and GP330B, AIS, and DRS4D not being found. The GP330B I tested direct to backbone with a single drop and still no connection. The Radar could it be a network problem as that isn't working to my computer and the AIS I haven't looked at yet.
I know this is a lot and hope I have explained correctly but if you can please help I need all I can get.
Needing to get wet
Cheers
Kevin J
Needing to get wet
Cheers
Kevin J
