I am the very happy owner of a Navnet VX2 system on my 4788 Bayliner
right now I have:
2 each 10" displays
1 open array radar
1 sounder
1 heading sensor
2 transducers
2 gps sensors
2 chart chips
1 layer 2 ethernet hub/switch
I plan on adding a second sounder and another display this winter (maybe two new displays).
My goal is to have a 100% fault tolerant system. Furuno equipment is extremely reliable, but all equipment does eventually fail, and I want full redundancy.
The challenge, and the question I have is how to configure the system to meet my goals? What I do not want to do is to have to reconfigure my network on the fly in the event of a component failure.
The issue I have is that from the manual you can only have one charting source and one position source enabled at a time. Can I have the system set up to automacially fail over to a second chart and position source?
The other issue I have is that the Ethernet hub/switch represents a single point of failure. If this device fails I loose connectivity to both my redundant sounder modules.
Here's what I was thinking of doing. If I divide my network into two completely separate VX2 networks that would give me the redundancy I'm after. The only issues I'd face is that Radar would only be available on one network, and routes/waypoints would only be on one network, unless I back them up to the other network using SD cards.
Do you see another solution to this?
I am very happy with my equipment and it has been very reliable. I'm just trying to meke it fully redundant.
Thanks...Kevin
right now I have:
2 each 10" displays
1 open array radar
1 sounder
1 heading sensor
2 transducers
2 gps sensors
2 chart chips
Thanks...Kevin
