billfishman
hi snips,
i am newbie to this forum and have just puchased the 295 I am about to wire up the transducer is it the same as the the b265lh. my question relates to tap settings.both hi and low frequency are wired to tap c ? does the tap setting just cotrol the output of the sounder?I am also wanting to be able to take the sounder out of the boat each time do you have any suggestions re plugs. i will be using it for deep dropping 500m does the transducer have LF sweet spot ,would you suggest 38-40?
