FCV 588 has stopped reporting the water temp and only indicates "---.-"
Tested with both B164 and a brand new B260 with same problem. Measured resistance of the transducer temp pin outs and are working / in spec.
Checked settings under Data and Temp Source is set to "Own".
Have tried restoring to factory defaults.
This unit while not brand new does not have many hours on it and all other functions are working.
Any suggestions where to find the problem? Any board level testing that can be done? Fishing without working water temp is less than ideal.
TY.
TY.
