I have the 588 sounder that was matched with an in hull M260. Unfortunately, something has caused one of the corners of the transducer to break off (?buckled) and can no longer seal the unit.
Looking for best option to replace the M260 and have been advised the SS175 wide beam through hull or the transom mount TM 260 would work well.
I mainly fish in 10 - 50 m but sometimes head off for blue fin tuna offshore.
My understanding is that the through hull generally gives better imaging and I may have a problem with the SS175 offshore. Unfortunately being a trailer boat, I cannot use the through hull 526TID HDD which could make use of resboost.
How will the 175 chirp transducer cope with the 588 and what would you recommend?
Thank you
Thank you
