I need help connecting my FCV585 and Garmin 527 via NMEA 0183. I’m using Port 2 on the Garmin and Port A on the Furuno. This is what I have and I’m not getting any communication:
Furuno Garmin
White (TX-A) Violet (RX-Port 2)
Yellow(RX-A) Grey (TX-Port 2)
Green,Blue Ground
I've tried this connection with and without the Furuno blue wire. The Garmin GND and Furuno Green and blue are all connected to a common ground.
The Furuno is set to NMEA 0183 in/out and TLL out. Also, I tried all NMEA 0183 settings (version 1.5, 2.0, 3.0) The Garmin is set to NMEA 0183 on Port 2.
I’m testing this on the trailer so the transducer is not hooked up to the Furuno but I’m not getting position info in the NAV box on the Furuno.
Any ideas?
thanks
Furuno Garmin
Green,Blue Ground
Any ideas?
thanks
