FCV-295
joe1958
Hi, hope some one can help,
My FCV-295 for some reason after turn it off, now it won't power on anymore, either I try disconnect and reconnect power cable, but it seams nothing happen no "beep" sound as normal turn on, use meter measure it shows voltage from small power board where is cable connected, thanks in advance.
Best regards
Joe
Joe 1958,
The FCV-295 has two fuses on the Filter board where you connect the power.
Make sure both fuses are good.
Joe1958,
OK, the next step will be to send it into your local Furuno dealer.
