HELLO, Thinking of adding a 1150 for bottom fishing in 80-250ft. Looking for transducer suggestions for a 33 power cat. Looking for recommendation for showing bottom hardness. Thanks
If your not going deeper than 250ft, I would tell you that the FCV1150 is wayyyyy overkill for that depth. Have you looked at doing hardness from the FCV800?
I agree with Sparky Wire—the FCV295/FCV1150 was designed as a 1–2–3 kW light commercial fish finder. Based on your fishing needs, I would recommend considering the FCV800 as a better fit.
All good.I've run many Furuno sounders over the last 35 years,582L,585,587,295 most with B260. Ran a B265 with the 295. I also ran the 295 with Furuno transducer custom mounted in a B260 faring. Take Care.
