Installing new NavPilot 711C
On the FAP 7002 CANbus power terminal TB12. What is the purpose of this terminal block?
If I have a N2K spine set up w power going into it form a 12Volt DC source, do I need to address this TB12 ?
Also, I plan on using a N2K drop cable into the TB11 CANbus block and connect all 5 wires w the other end connecting directly into the N2K spine. When would I need to terminate the white and blue wire w the provided resistor?
Thank you
Thank you
