FA-50 NMEA 0183 output
Jacob_DK
I have an old FA-50 that I want to connect to ny Seatalk NG backbone. I have all I need but the info on which wires in the main cable from the FA-50 are the NMEA0183 output and which wire is GND and which is DATA ?
Help will be much appreciated!
Jacob 😎
Hello Jacob,
To transmit NMEA0183 data from the FA50 main cable, you would use the white and blue. White being positive and blue being negative.
Thank you,
YachtyBoy
Hi YachtBoy,
Thanks for your reply ! That just confirmed what I was thinking.
I have another problem : The transponder only transmits but does not receive any data ?! I have run the Transponder test embedded in the AIS and all reports are OK. Do I need to do master reset ? If so, where and how do I do that ?
Just one more and probably stupid question : does the AIS also have a receive "channel" ? If so, which wires should I use for that ?
I'm not sure if the NMEA0183 is bidirectional ?!
0183 wires has transmit wires and receive wires. Normally you would no need to send any 0183 data to the FA50. What 0183 data are you trying to have the FA50 receive?
I am not trying to send data to the FA50. I just want to make sure all is connected correctly.
All I need is to receive GPS and AIS data.
I don't recommend the FA50 as an GPS source but it should receive good targets if connected to a good AIS whip. (Note VHF whips should not be used for AIS. The Whip needs to be rated for AIS or both AIS/VHF to be used) I never recommend sharing a VHF whip with the AIS as someone will lose and the external splitters are typically high failure rate items.
