etr-30n transducer set up navnet vx1 for r209tidn
  • Thread starter Thread starter hookena
H
hookena
aloha
is there a correct transducer selection from the menu for the r209tidn to operate in 38khz at 3kw and 200khz at 2kw in the naming menu? could you also please verify the tap settings for this transducer in the etr-30n/bbff3?
thank you.
Hookena,
The 209 won't be in the BBFF3 list of transducers, so you will need to manually enter the frequencies. Set the taps for "B" for 38Khz and "C" for 200Khz.
