DST800 Transducer housing
svjeorgia
Do you know if the DST-800 depth/speed/temp transducer will fit into an Airmar plastic housing for a Raymarine ST60 speed/temp through hull?
Regards
Paul
Airmar made the transducers for the ST60 series as well as the DST-800 for Furuno.
They offered a few differnet models for the ST60 so it is difficult to determine an answer to your question with a specific model.
You might want to check the Airmar website as they offer a cross reference section that might help you.
If I was replacing triducer to triducer it would have worked fine. But the old transducer is speed/temp and the new one is speed/temp/depth. The new unit is a larger diameter.
