Just installed a DRS4W wifi radar. Here are my first impressions.
1. The included power cable is almost as thick and stiff as the multiwire cable in my 30 year old radar that I am replacing. So no convenience there, which is the main selling point of the radar. The radar only uses 2 amps so I can't imagine why they supply this thick stiff cable. It is heavily shielded but in a normal mast there are only dc wires see no shielding is needed.
2. The power cable connects outside the radome. The connector, exposed to the elements, will surely corrode in time, regardless how many layers of tape you apply over it. Bad design.
3. The supplied power cable uses untinned copper wire. They should have use a proper marine grade wire. This wire will eventually corrode internally after the 2 year warrantee period is over.
4. The warning beep, which sounds if a vessel comes into the selected segment, is too low to be heard over a diesel engine. The app should be written to use the loud sounds that an pad is capable of.
5. I called tech support with several questions. The 2 techs I spoke with were not knowledgeable or helpful. Even slightly rude. They should have referred me to a more knowledgable person.
I like the ability of using an pad rather than a stand alone display. I have yet to use the radar at sea and these are just my first impressions.
