I am looking at upgrading from a NN3D MFD12 to a TZT or TZT2; and upgrading from a DRS4D to a DRS-NXT. The combined LAN/power cable from my MFD12 to DRS4D would be a bear to tear out and replace. Any reason a competent marine electrician couldn't separate the LAN and power wiring at each end of the DRS4D cable so it can be direct-connected to ship's power (no PSU) and the ethernet switch and serve the DRS-NXT also? (Come to think of it, the existing cable is already separated between the RJ45 and the power wiring at the radome end, isn't it? So it would just be at the MFD end that the tech would need to modify the cable?)
thanks for advice
thanks for advice
