Installing transducers next week. Want to see if there's anything glaringly bad about these install locations:
1) 165t B54 where the red marks are: red square in bilge, red x's on bottom of hull. Will most likely be relocating that discharge thru hull sitting 6 ft forward of here.
2) Also will be installing B175hw approx where the blue x is (forward of raw water intake thru hulls). This seems more straightforward but making sure its ok too.
Boat is single inboard Shamrock 270 Mackinaw
* Yes those two wire looms are no longer near/touching the shaft, both hanging up where others are above.
** I'd prefer to get the 165t-B54 as close to the centerline as possible. Obviously I'll still need to have room for working on shaft/shaft seal. Any issues with interference getting this as close to shaft as possible?
Todd
Todd
