Hi,
I am looking to upgrade from a Dff1 w matching box to a DFF3 that I came across for $100.
I would like to update the software via PC is there a package like with the DFF1? I believe I am V 1.05 if the dff1 check version works the same? I have no MFD.
With the transducers they are 1kw non chirp and both work fine on the Dff1.
One is a dual 200/50 mounted in the keel, rubber or urathane from a old jrc I had in early days, I only use 200 khz - Tap A ?
The other is a 50khz Radarsonics 16 degree beam in a 3000 housing Tap B?
Cheers Luke
Cheers Luke
