Have a DFF3 installed and currently connected to R299. Also installed in the boat is a CA50/200-1T that I was previously using with a FCV-585 and then later with a DFF-1.
Prior to getting the R299, I used the DFF-3 with the CA50/200-1T (mostly LF) and it worked really well. What I'd like to do is connect the DFF-3 to the LF side of the R299 and the LF side of the CA 50/200-1T. If I were to try this, my assumption would be that the R299 LF wires would connect to the LF input of the DFF-3 with a "C" Tap setting (as it is now). If connecting the 50kHz wires to the HF input of the DFF-3 is possible, would I use a "B" tap setting?
Thanks in advance for any info.
