Just finishing up a new boat for launch this summer. Installed a DFF 3D & 165T-B54, a B275LHW that will connect directly to a TZT16 ( or TZT16X) and a DFF3 UHD connected to a R509LM. A SCX20 will be installed as well as Time Zero Pro. Several questions.
Will there be a way for to use soundings from the DFF 3UHD to record the bottom in deep water??? On my current boat, depending on bottom composition the 165T looses bottom between 600-900 feet. Granted that the R509LM is a single beam sounder but it would be nice to record the bottom in deeper water when the 165T fades out.
Time Zero Pro does accept data from a single bean sounder. Your Thoughts on this??
Is there a detailed user manual on the operation of the DFF 3UHD? The brochure mentions it can be used in the CW mode. I have not been able to find what setting are available in the CW mode. I am currently running a FCV1150 ( now 24 years old and running like new) . That unit has a very robust menu for settings. Will the DFF3 UHD have a similar menu in the CW mode?
