Data box size(speed, etc)
Jagsare1
When you swipe from the left, a large box(1/4 of the screen) opens. That box is entirely too large. Is there a way to make a small data box that contains things like speed, DTG, TTG, etc? This was available on the top of the screen on the VX2. Generally, it did not take up much space on the VX2.
There is no way to change the size of the databox, just the data itself.
You can select just the data you want and adjust the transparency.
Go to settings in the plotter menu and adjust NavData Transparency. You can go from 0 to 80%.
Wow. Terrible design. It prevents using the device in split screen mode because it takes up too much room. Somebody wasn't thinking with that design and I sure would like to see it fixed in an update.
