Choosing Correct Transducer on TZT2
Beachman
New to me boat and to Furuno. I did a Software update and lost my transducer setting. I have an Airmar CM599LHW. I tried to Manually set up in transducer in set up type and that did not work. When I picked 200Khz:50/200-1T from the model list it is working.
Am I getting the most out of this Transducer by leaving it on this setting or is the a better one to choose? Did i do the Manual setting wrong? Picture attached. Thanks
Looking at your settings you appear to have more than the internal TZT2 sounder because the TZT2 wouldn't be having you setup a bandwidth. What sounder are you using?
Yes, your manual settings are perfect. Power and impedance matching is covered by your TAP settings inside the DFF3 sounder box.
