Can you have 2 blackboxes
PeterG
I plan on getting the dff 3d uhd black box with the dff3d 165t/275lhw-12p transducer. I also want to add dff 1uhd + to get bottom discrimination and accufish. Will i need anything extra...can my multi function transducer work for both black boxes.
The 165T/275LHW-12P will work for the DFF3D (165T) and the DFF1UHD+.
However, Accufish and Bottom Discrimination require a CW (50/200) transducer.
You can connect a medium frequency CHIRP and a 50/200 to the DFF1UHD+ to give you a CHIRP image with the Accufish and Bottom Discrimination.
For that I would suggest a 165T-50/200-SS260 and something like a B175M. We would need to know your boat make/model and see some pictures to make a good recommendation.
The boat is a North Coast 255 HT. It has a motor bracket so that is why we plan on having the 65T/275LHW-12P installed with a pocket mount to give transducer clean water. The boat bottom is a bit tricky since it has a 2.5 inch protrusion down entire bottom. The bilge access is very roomy for working on pocket for transducer 3. NorthCoast 255 HT Hull from stern 2.jpg1. NorthCoast 255HT fromHULL from bow.jpgNorthCoast 255 Bilge access with open panel.jpg
The boat is a North Coast 255ht and it has a motor bracket. We plan to have a multi pocket transducer so it will have clean water. The bottom has a 2.5 inch protrusion that makes the pocket install a bit tricky. The bilge access is roomy fortunately. Thanks for your input...
The recommendation of the 165T-50/200-SS260 transducer for Accufish and Bottom Discrimination in this thread contradicts other recommendations on this form. Please confirm if it is recommended/compatable for Accufish and Bottom Discrimination. Thanks.
