Gabewilliams04
I have a 10.4” VX2 paired with a 25kW open array and a transom mounted transducer. I recently acquired a PG-500 with hopes of utilizing the overlay function with radar and the plotter. I’ve connected the PG-500 to 12v power and used a blue data cable to network port 3. I have cleared the memory from the PG-500 (it is a used unit) and run the diagnostics test. All good. The overlay option in “Display” is grayed out and unavailable.
Not sure what the next steps are. I don’t find a way to select this device as the heading sensor, nor is network port 3 available in the set-up screen.
Any suggestions? Thanks!
