Adding additional Displays to Touch 2
ELGATODOS
I would like to add a few displays to my TZ Touch 2 in the tower. From what I understand the 15" display can provide output to different monitors. I understand I would need to use the MCU002 or MCU004 remotes to toggle back and forth between screens correct?
As far as display/PC/12V displays are there any requirements besides it being a standard widescreen PC monitor?
My thought was getting a few 12V car headrest type displays with HDMI inputs and using those and controlling them with the MCU004.
How do I go about connecting 2 or more monitors to the TZ touch 2?
Thanks, Bryan
The TZT2 has an HDMI output that you can connect to a monitor. It will be a mirror of the main unit. If you put a MCU control (MCU002/004/005) by the monitor, it could offer you a second station BUT it you couldn't use both stations at the same time without fighting each other. If you need full control at both locations at the same time; you would need to get another TZT2 MFD.
