585 screen information
Does anybody know how to move the depth numbers up from the bottom left of screen to top left-the numbers hide some of the bottom particularly when dual frequency used and is zoomed in
The depth number in the bottom left of the screen cannot be moved, but the size of the number can be changed under Menu, Display, Depth Size (small, medium or large).
Fush1,
The Data Boxes (upper left-hand corner of the display) can be programmed to display Digital Depth, however the numbers might not be large enough to see at a distance.
Changing the size of the depth number at the bottom left of the screen may help your particular situation of having the bottom return covered up, but you could also switch to manual range and change the range so the bottom return is just above the depth number.
Thanks for the help-i will try both when out next -It would be a handy feature on Furunos to come especially when sounding deep(300 m +) you need every pixel used that you can !-some other sounders already have it
