Mehmet Okur
Does Furuno XL have the Auto Range Shift feature, which is necessary for bottom fishing, which is available on non-touch devices?
When you select TZT3 Menu Dual frequency, you have to zoom manually, is this still the same in XL or has this been fixed?
Is it possible to use Auto Range Shift when using Chirp Dual Frequency?
When you switch between H/L frequencies while Bottom zoom is selected, the data of the frequency that is not visible on the screen in the background is empty? There is no history on the frequency in the background, has this been fixed?
When working at challenging depths (e.g. 1KW LF over 650 meters), it is necessary to slow down the display speed extremely when it is difficult to receive the signal. If you don't slow it down too much, the screen jumps are too much. Everything becomes unintelligible.
We have many more expectations that I will write about. But these are the important ones.
Thank you.
Thank you.
