50khz noise on fcv295
WAFisherman
Gents,
Look on the left, 50khz with engine running, engine off on the right. I am hoping it is because I'm only in 8m of water...noise picked up from motor. On 200khz it was crystal clear at 30knts in 22m. Transducer is a B275LHW dual chirp
WAFisherman,
Couple of questions.
Do you have an alternator on that engine?
Where is the shield wire grounded to for the low frequency?
Also I see you are using the Interference Filter in the AUTO mode, have you tried setting it to medium?
Hi Snips,
The motor is the brand new Suxuki DF250 APX outboard (digital throttle). It has the magneto. I tried all 3 settings, low med and high, high was marginally better. The transducer has the 9 pin black plugs on the end, so I have an adaptor plug with bare wires connected to the 295. The ground wire is clamped to the chassis
Cheers
WAFisherman,
Normally the Blue (or Blue with white stripe) will go to terminal 1. You can try swapping the wires but I don't think it will help. This type of interference is more prone the appear on the LF side then the HF. However if you go to a deeper depth range (600ft+) and set the HF gain to 10 you might see the same pattern start to appear on the HF side. At this stage either adding or removing the grounding wires may help.
Snips,
Just looking at the wiring on furuno page for the chirp transducers, black/white on LF go to terminal 1 and HF terminal 1 is blue. I have connected blue/white to terminal 1 on LF side for the B275lhw, so I thought this could be the issue.....
Cheers
WAFisherman,
Thanks for giving that to my attention, I will have that corrected.
Electrical Interference issue solved.....well sort of. I connected the 295 to an independent battery and 50khz reads crystal clear at speed ie 30knts (in 20m)!
I think I will try now to connect a noise conditioner to a wire feed from the main battery and see what happens.
