1930 Radar
Will it be possible to use the RSB-0035 open array antenna of a 1930 Radar with an RDP-139 VX1 Display? If yes, what would one need and what is for and against?
No, the radar scanner from a 1930 radar (RSB0035-021) use a 32 volt tuning voltage and the NavNet series one 10.4" (RDP139) uses a 12 volt turning voltage. They will NOT work together. The (1989-1993) 1930 radar will not work with anything newer that is sold. You would need to repair the 1930 display or seek out a used one. You could also use a suitable older display from a FCR1030 or 1760. Due to the age, I would not recommend putting a lot of money towards this radar.
