Hi
Want to connect either a Standard Horizon Explorer 1700 or a Garmin EchoMap 94SV to my 1715 radar.
I have purchased the 000-154-028 1 X 7 pin NMEA connector.
Standard Horizon NMEA info:
BLUE - NMEA GPS Input (+)
GREEN - NMEA GPS Input (-)
GRAY - NMEA DSC Output (+)
BROWN - NMEA GPS Output (-)
NMEA 0183 Input (4800 baud) GSA,GSV,GGA,GLL,GNS,RMC
NMEA 0183 Output (4800 baud) DSC and DSE GSA GSV GGA GLL RMC
NOTE Some GPS chartplotters have a single wire for NMEA signal ground. In such case connect NMEA input(-) to the GPS chart plotter single NMEA signal ground wire and leave the NMEA output (-) open
Garmin NMEA Info
BROWN - NMEA 0183 Internal port Rx (in)
BLUE NMEA Internal port Tx (out)
BLACK Ground ( power and NMEA 0183)
NMEA Transmit - GGA, GLL, GSA, GSV, RMB, RMC, RTE, VTG XTE
Which unit would you recommend to use for supply of NAV info for the 1715 and what wires need to be connected??
I see the NMEA info in the 1715 Opeartors manual listing the info that it can take in, but have not located wiring color info for the NMEA connector cable Furuno #000-154-028 1 x 7 pin. Seems the NMEA 0183 "standard" is rather loose.
Thanks in advance
Steve
Garmin NMEA Info
Thanks in advance
Steve
