On a few year old 1623 radar, is it normal to have 2 or 3 low to medium tones, similar to humming, emanating from the radome in transmit mode? It wouldn't be heard over engine noise?
Also, to remove the cable from the boat, would you unplug the 7 (or is it 9?) pin connector inside the radome to pull the cable out through routing holes from the display end?
Can the connector pins be removed from either end of the cable then reinserted after the cable is run without damaging the integrity of the cable?
