Tailin strange":2xir9r8t said:
			So if a 4ft 25kw x class is say a 10/10 at finding birds is the nxt 200 watt 4 foot a 9.5/10? Or less than that. If it’s that close, I may be making a swap to the nxt for its other benefits. How often does the magnetron need to be replaced on the x class?
I can answer for a 6' DRS25A-NXT versus a 6' 25kW magnetron.  Using your approach, I would say for birds if the magnetron is 10/10 the NXT is probably a 10/10 at ranges out to 4 miles or so.  At longer ranges, the magnetron is a little better, so maybe at 6-8 miles the NXT is 9 or 9.5/10. In real life, I would say they are very comparable at least for me because I don't chase birds at super long ranges where I fish -- the tuna will be gone by the time I get there!
On the other side of the question, I find that the NXT is significantly better for navigation because of the improved ARPA/Doppler target tracking and ability to show targets at very close range.  It is also great at showing thunderstorms and rain at very, very long ranges, better than I recall seeing with the magnetron.
Also bear n mind that it is within the realm of possibility that Furuno may refine the performance of the DRS25A-NXT through software updates since it is at the beginning of the product cycle.  There is a whole lot of signal processing going on with these radars and the software is an important aspect of performance.
