BBWX4 Error
SilentRunner
I just installed a BBWX4 in my Furuno system. It turns on and flashes a series of four (4) red lights. It is connected to a TZT2 through a Hub 101. The TZT2 display sees the BBWX4, when I unplug the RJ45 connection the TZT2 display beeps and shows it has lost connection. when I plug it back in it connects however the red lights continue flashing a series of 4. The Display has been set to Sirius as a weather source.
Any ideas?
If you use the chart on page 22 of the manual, it should be able to help you determine what light pattern it is flashing.
https://www.furunousa.com/-/media/sites ... _guide.pdf
I would ensure that you are not using the old style HUB101 from the old NN3D days because it isn't fast enough for the BBWX4. The hub should be the newer board time purchased in the TZT-TZT3 days. If you want to check the board, at the top right of the circuit board is a -00 -11 -22 or -55. The -55 is needed for TZT and above.
If it is flashing antenna error, you should check the antenna run and connection.
