dugsmith98
Navnet 3D 12” with MFDBB, and hub 101. Second display at helm, and data from FA 150 AIS and GP 150. Couple of times over the last few weeks I would get an error on he display coming from the MFDBB acting as the master, and it was on a blue screen.always started with
”a problem has been detected and windows has been shut down to protect your computer.
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is the first time you’ve seen this error screen, restart your computer.
‘Check to make sure any hardware or software is properly installed…”
I would restart the computer and it would work fine for a day or two and it then happened again but different error message in Caps
PAGE_FAULT_IN_NONPAGED_AREA
Then yesterday, I couldn’t get it to reboot and started to get error beep codes coming from the black box. Four longer and then four shorter beeps in pretty rapid succession.
From what I am seeing in other posts, I’m ready to disconnect all peripherals and do a factory reset on the install wizard screen, if I can get hat to come up next time. Any other thoughts or suggestions, since it feels like I might be at the end of life on this.
