Y cable
fishracks
I have a single 12" tzt3 with a 225T-TM904 and want to add a 175hw transducer could someone please post the correct y cable to use to hook it up Thanks
Your sounder is taken with the side-scan. To use the 175HW, you would need to connect that to a different machine with available sounder port. The transducer will have a 10 pin connection and you simply attached the 10 pin to 12 pin adaptor that came in the box with your other MFD.
Thanks for the info kind of disappointing I was either given bad info when I purchased the 175 or I misunderstood him but asked if I could run them both on the same machine I was told yes I don't think I have the room for another machine at the moment until my 585 dies on me but for now I'll just disconnect the side scan
They might have confused it with a TZTXL. TZTXL has two ports and you can still run single chirp and side-scan on one machine but that isn't the case with TZT3.
