southatlantic
Hi,
I need a bit of advice.
Last weekend I noticed an issue that was not there before. I have 2 MFD12s on my flybridge. I use one for radar and the other for plotter/sounder. I noticed that the selected waypoint for "Go To" on the plotter MFD was not being picked up by the radar MFD... I had never had this before. I selected the same waypoint manually on the radar MFD, pressed "Go To" and it worked fine then. Next waypoint, same thing, all over, again. I did not have time to investigate further and will be away from my boat for a couple of weeks ( I currently get very little time on the boat...).
What is the most likely cause? Disconnected wire, inadvertently changed the set-up? :huh What should I investigate first? :think
Thank you for your help!
