I kinda thought so because last night I just installed V.8 software update in my TZT2 and tried the new” check for software update” to see if I could update the NXT. I did download the instrument update and tried several times to update my DRS4D-NXT last night. Each time I tried the instrument update it would start off OK and the yellow bar on the bottom of the FURUNO screen would scroll from left to right for several minutes and then I got the “Now Initializing” page for a couple minutes but would not move onto sensor update (uploader) window. Instead the screen would return to my chart page. I tried it several times with both a usb memory stick as well as a freshly formatted (fat 32) Micro SD card in a USB adaptor. I must have tried 3 or 4 differed cards and usb memory sticks. Each time I got the same results. Im thinking it might be something I missed when I copied the files onto the cards. The way I copied the down loaded files onto my card was. I opened the sensor software update folder and saw that there is one folder, the uploader and 4 other files. I put those 4 files and the one folder onto my card/memory stick. I tried that several times and each time it failed I would take that card and erase it then re-format it (fat-32) then the uploader folder and the 4 others files.
Since that method doesnt work I tried opening the uploader folder where there was 15 folders and 9 files and copied that onto the card/ memory stick and still it wouldn’t work. What am I doing wrong?
In any case I now have a couple more questions about the V 8.01 update for the TZT2 but first allow me to explain my install of V 8.01 last night .
prior to the V 8.01 update las night I saved all my settings, routes and points to a micro sd card then installed the v 8.01 update. Everything went in fine so I checked my files and the map and all my points, routes and settings were the same as before. Didn't loose any of it, then I remembered I still needed to do the factory reset/clear and realized thats where ill loose my settings, points and routes.
I preceded to do the factory reset. I noticed there is a new way of doing the reset via the SERVICE MAN selection. This is the first update I have tried using this method. It was much easier than the old way and the new Furuno directions were very easy to follow and understand. Right after I did the factory “service man” reset I went back to check on my points, routes and settings and sure enough they were all gone so I figured the reset was good.
I then went and uploaded my Points, Routes and settings I had saved prior to the update. Again everything went good and my points and routes were now visible in my files and charts but now my chart started spinning and a red message popped down from the top of the screen, “Heading lost. I thought that was weird because most of my other settings had uploaded.
I went into the data source page and noticed that my PG-700 heading sensor was set to TZT2 and I changed it to the PG-700. Now my chart isnt spinning and the “heading lost” message had disappeared. When I open up the Data Source menu on the right side of the screen there are two columns “Current” and “Preferred” what do these mean? I assumed that the “Current column indicates what the TZT2 is using at the moment for a sensor and the preferred column is the sensor I should be using. Is that correct?
I remember that when I up loaded the old settings I had saved prior to the 8.01 update that the data source information would also be included when saving and uploading “Settings”. Is this a possible bug in the software that data source is included into settings when saving and re-installing after an update? Do I now need need to go through the data source and manually re-set everything?
I went from V4.01 to V 8.01 on the tzt2 but when I did past updates I don’t ever remember ever having any issues like this with the data source not being included when saving and then up loading back into my TZT2 after a new software update.
